Greddy TD06 25g turbo kit to fit RB25DET
Posted: Sat Sep 13, 2008 3:44 pm
This is a kit designed to fit an R33GTST, but I had the exhaust front pipe modified to fit the R34GTT, but it could be converted back again.
TD06 with polished housing (phone not included)
Greddy external wastegate with stainless hoses
Modified front pipe, which is also modified to plumb the screamer pipe from the external wastegate back into the exhaust with a flexible coupling onto the added flanges. (not shown as I left it at work)
This is how it is used on the road, with the screamer pipe (on the right) venting the exhaust gas to atmosphere
For trackdays, the flexible section is plumbed in, joining the screamer pipe to the front pipe.
The kit also comes with a Greddy top mount manifold, which is currently still bolted to the old engine and various bits of hose and pipe. You will need to get the odd bit of hose/pipe to complete the instalation and fit your own set up.
Good turbo kit that gives around 500bhp depending on your other mods etc.
