Alpine CDA7998R CD/tuner - Copper chassis, pre-out unit (no built-in amp). This was special order, Alpines 'phantom face' unit - when turned on the whole front end pops out of the body for a bigger display than normal DIN size then fully retracts back into the unit when switched off leaving a blank plate.
Genesis Dual Mono Extreme amplifier - Hand built in the UK, top of the Genesis range. Comes boxed with power certificate. Cost
