Live Data Monitoring of : - battery voltage, engine speed, vehicle road speed, coolant temperature, intake temperature, injector duration, knock, lambda, throttle postion, boost pressure.
Oil pressure and oil temperature via additional sensors.
Current and historic fault code reading.
ECU and fault code reset.
Shift light control.
User adjustable alarm monitoring of : - battery voltage high and low, boost pressure, coolant temperature, oil pressure and temperature via additional sensors.
Water injection/nitrous control.
Record peak reading for engine speed, boost pressure, road speed and coolant temperature.
Clock.
Plug and play fitment.
User selectable options for unit display ie. bar or psi, degrees c or degrees f, mph or kph.
PM Naomi if interested
The data monitor HAS a pod mount with it
It'll fit any scoob 2001 and onwards
