Only removed due to now having an alarm with the TT feature.
Silver face with digital display
Identical product shown in this pic...
DC TURBO TIMERS
There are two types of turbo timer available from Blitz; the FATT DC and the Dual DC.
They come in two parts, a control unit, and a front panel, which means the display is very small and easy to mount.
The Blitz turbo timers are also fully automatic, working out the correct length of time your engine should be left idling to give the turbo bearings time to cool down, based on the way the car has been driven (the engine speed is calculated by measuring the small fluctuations in supply voltage the engine produces as it runs). This takes the guesswork out of running your car after a drive and will help to keep the engine and turbo in top condition.
The Dual DC features include:
* Auto turbo timer
* Manual turbo timer
* Lap timer
* Boost pressure
* Peak boost pressure
* Overboost warning
Both timers are black. The dash mount head unit measures (W)86mm x (H)26mm x (D)16mm.
The proper Subaru connecting harness for this is a separate item and retails for
