Winter project - GPS laptimer
Posted: Fri Mar 09, 2007 3:01 pm
Back in december i was looking for a little project to keep my brain alive over the winter months and i thought id knock up a bit of GPS lap timing software, at this time id not seen Virtual Cup :oops:
Anyway, the softwares got to a fair usuable state so i thought id share the fruits of my labour.
Local circular route, with lap times displayed
Close up showing a tight left turn at a junction, coloured lines indicate laps
Same junction but using cublic splines to show more acurate guestimated curves between points, this is actually a cheat at the moment as its not weighted by speed.
Each cube you see or node, is a data packet from the GPS hardware, and they come roughly 1 second apart, as a lot can happen in a second especialy on track databetween these points will all be calculated.
At the moment without calculating between points its acurate to the nearest second, but that refinement will come.
Software will run on any modestly grapically endowed pc/laptop that will handle DX7 3D modes. GPS interface should be any serial NMEA standard device (including USB ones with emulated coms ports).
The screen is formatted 800x600 as orignally i had inteded to write it for a sort of touch screeny incar pc, but ive decided driving the car round tracks is more fun than wiring in pc components
:-D
Please apreciate its fairly earley on in this softwares development cycle and itll be buggy and do daft things, Its by no means up to the levels of Virtual Cup, but its a fun little thing that keeps my brain working, if anyone wants to try a copy, PM me your email address and ill send a copy over with a keyfile.
Id apreciate any feedback posative and negative (dont worry you wont offend, our testing department at work are evil) you can give + any data youve recorded
If your laptops not up to the 3d mode then you can run the software in record mode, and then analize it on the home pc later.
I thought id keep this in the members area for the moment till its a little more 'stable'/
Have fun
Maff
:-D
Have fun
Maff
