what exactly have i bought
mirage
Post by mirage »
asked abbey for 2 front uppermount suspension arm bushes, they said whiteline do a polyurethane kit i said ok this is what i got.
says fornt camber adjusting kit, allows for +/- 0.5 degrees camber change and adjustable whilst on car.
is this what i needed and more?
Image[/img]
R34 Nur Engine
Tomei manifolds
Endless 6 Pots
Nismo Z-Tune Plenum
PFC
GT2860's
etc.......
gtst lad
Post by gtst lad »
I'm not going to be alot of use here as i've never used this kit before but the pic in the instructions does show the front upper arm, i do know they're a pig to fit though.
When i had the same problem as you i bought these http://www.driftworks.com/catalog/produ ... table-arms
Best advice i could give is ring abbey and talk it through with them, i've bought a fair bit of stuff off them over the years and they've always been very helpful when i've rung them about things i've been unsure about 8)
mirage
Post by mirage »
im not too worried about fitting as that will be APT's job :D
as long as i have the part i need to pass the MOT anything else is a bonus.
R34 Nur Engine
Tomei manifolds
Endless 6 Pots
Nismo Z-Tune Plenum
PFC
GT2860's
etc.......
gtst lad
Post by gtst lad »
It does look like you have everything there.
I'd of said the yellow bushes with the bolts in them go in one end of each upper arm and the other bits go in the other end of each arm then to adjust camber you rotate one of the bushes which will have an off center hole, can't really tell from the pic which one you rotate though.
hope that made sense :?
323ian
Post by 323ian »
It looks like the yellow bush has an eccentric hole to adjust camber.
Those are the bushes for the upper wishbones.
I ended up paying
mirage
Post by mirage »
these allow for camber adjustment, just need to buy the rear set now.
ill get SCA to set it all up after eerything is fitted.
R34 Nur Engine
Tomei manifolds
Endless 6 Pots
Nismo Z-Tune Plenum
PFC
GT2860's
etc.......
mirage wrote: ill get SCA to set it all up after eerything is fitted.
Don't. It's up to you mate, but I made that mistake. Go to someone that knows these cars.
mirage
Post by mirage »
who would you reccomend stu, as i will go there instead.
R34 Nur Engine
Tomei manifolds
Endless 6 Pots
Nismo Z-Tune Plenum
PFC
GT2860's
etc.......
jungle-jim
Post by jungle-jim »
what about AP tuning?
