TLA's
Posted: Wed Nov 15, 2006 11:30 am
by duncan
The whole tuning/modding world is littered with three letter ackronyns - here are a few to start the ball rolling
AFR : Air to Fuel Ratio
MAF : Mass Air Flow (how much air is going into the engine)
Posted: Wed Nov 15, 2006 12:07 pm
by Ben
AFM : Airflow Meter
CAS : Crank Angle Sensor
Posted: Wed Nov 15, 2006 1:00 pm
by TonyB
ACT : Air Charge Temp (See MAT)
AFM : Airflow Meter
CHT : Cylinder Head Temp
EGT : Exhaust Gas Temp
MAP : Manifold Absolute Pressure (Air Pressure in the Inlet manifold)
MAT : Mass Air Temp (Temp of air in inlet Manifold)
I could do some more but I will let others have a shot :lol:
Posted: Wed Nov 15, 2006 1:04 pm
by duncan
AFM : Airflow Meter
EGB : Exhaust Back Pressure
Posted: Fri Nov 17, 2006 11:58 am
by PhatBob
AFM : Airflow Meter
BLD : Boarderline Detonation (Point of ignition timing where first signs of detonation occur)
CLT : Coolant Temp
IAT : Inlet Air Temp (See MAT)
LBT : Lean for Best Torque (Leanest air fuel mix for peak torque. For Gasoline 0.86Lambda (~12.5:1 AFR))
MBT : Minimum Best Torque (Earliest timing point where peak torque is produced)
WOT : Wide Open Throttle
