Page 1 of 3
Mount for 45 x 22 mm ACT gauge
Posted: Mon Sep 18, 2006 11:27 am
by duncan
I have an ACT gauge but need a mount for it to be mounted in my car dashboard landscape rather than just slot it into ta switch hole (it would be the wrong way up) - wanting to do this as the back of the gauge looks a little industrial and wanting to keep it smart
Does such a thing exist - or will I need to fabricate (or get someone else to fabricate) one?
FYI gauge dimensions:
Cut out required is 45mm x 22mm. Bezel size is 48mm x 24mm
Thanks
Posted: Mon Sep 18, 2006 11:41 am
Sounds like a question for Mocom
Posted: Mon Sep 18, 2006 11:51 am
by duncan
gonna chat to him a little later on today hopefully as I have all the bits for my Ram Air Induction sorted now so may need to make a few adjustments....
Posted: Mon Sep 18, 2006 6:44 pm
by duncan
anyone want to give me a hand wiring this up ... I am rubbish at electrics
just needs one wire to 12V via a fuse and another to ground
Posted: Mon Sep 18, 2006 6:59 pm
by 323ian
Just put the black one to a bolt on the dash somewhere and the red just needs putting into a switched live such as a wire from the ignition.
Have a fumble round with a multimeter.
Posted: Mon Sep 18, 2006 7:06 pm
by boxy
Have you got a picture of the gauge so we can get an idea of what could be made for it?
Posted: Mon Sep 18, 2006 7:11 pm
by duncan
323ian wrote:Just put the black one to a bolt on the dash somewhere and the red just needs putting into a switched live such as a wire from the ignition.
hmmmm easier said than done for me
Posted: Mon Sep 18, 2006 7:15 pm
by duncan
Posted: Mon Sep 18, 2006 7:17 pm
by 323ian
do you have a digital clock in the car, that looks about the same size and could be a stright swap?
sorry to sound silly but what does that display?
Posted: Mon Sep 18, 2006 7:18 pm
by boxy
Can you not cut a rectangular hole in the dash and make a mount behind for it to fit in?
