I know this sort of thing is common on most forums, but the collated information on this forum will help with any potential group buys.
Please cast your vote.
What oil do you use?
Silkolene Pro S 10w 50.
From Oilman, Opie Oils, they even sent me some gearbox oil for free after their original stuff they sold me didn't work particularly well.
JC
JC
- Miniwilliams
20W50 Milers semi synthetic, i need some thing thick for me gear box.
PM or E-mail me some details
- Miniwilliams
I would have said NO to that. The oil cooler will help keep your oil in good order for longer as it's not running past it's best design temp.323ian wrote:What is peoples opinion on oils when they are running an oil cooler, do they change the grade they use to compensate for the lower heat in the oil?
But won't put thinner oil in because of it.
agreed with aboveMiniwilliams wrote:I would have said NO to that. The oil cooler will help keep your oil in good order for longer as it's not running past it's best design temp.323ian wrote:What is peoples opinion on oils when they are running an oil cooler, do they change the grade they use to compensate for the lower heat in the oil?
