Money CAN buy happiness...sometimes!
Posted: Mon Jul 21, 2014 10:31 pm
I'm thinking of going down the turbo charging route pretty damn soon. I'd like to buy a TD04L however, I've got a few questions.
1. Should I buy the TD04L-13T and then buy either:
A) TD04L-19T cartridge and swap them. What additional work would be involved in this - bore out the compressor housing?
B) Buy the ARD Tuning 19T compressor wheel conversion as this has the appropriate clearance as the 19T compressor wheel isn't tall enough to clear the stock CHRA body? Then a straight swap from 13T to 19T can happen without any milling.
C) Spend a little bit more and get a TD04L-19T straight up to avoid any hassle/further costs?
2) What maintenance work am I looking at to ensure the turbo setup doesn't fail on me spectacularly? Just regular servicing every 5,000 miles/1 year, what oil, etc?
3) Is there anything I need to be wary about when buying a TD04L, i.e. play in compressor wheel, knocking/ticking etc?
Thanks!
Thanks!
