Mr2 issues.
Posted: Mon Sep 30, 2013 6:44 pm
by pedGSR
So here's the story. Last Monday the mr2 cambelt snapped. Bad times. But at least it gives me a chance to sort a major oil leak out.
Remainder of belt removed. Pulley finally removed. Found a perished crankshaft seal and the oil pump housing leaking. New gasket required. BUT do you think I can get one? All day going to various motor factors and nothing. The crankshaft seal I can order off tinternet so no prob there. But can't even find anywhere online to get the oil pump housing gasket.
Here's the question. Do you think I could make a gasket out of some thin rubber? Something like an inner tube thickness? Because I'm wasting time tryng to find one.
Pete.
Posted: Mon Sep 30, 2013 7:19 pm
Speak to Steve Vince (used to run the Mr2 race series). A few of the racers still run these so you should be able to find a solution mate, so either check the forum or email Steve and go from there
Best of luck :thumbs:
Posted: Tue Oct 01, 2013 7:11 am
by Daniel
Buy some motor grade RTV silicone. Apply and let it set with no water, job done. :thumbs: (personally used this a lot on the truck instead of gaskets.)
Posted: Tue Oct 01, 2013 7:33 am
by pedGSR
Cheers Dan had considered using that. Just slightly concerned it might not hold up to the pressure. And as it's a ballache of a job I only want to do it once!
And stu, do you mean he is on this forum? Or another one?
Ta.
Posted: Tue Oct 01, 2013 7:46 am
by Daniel
If you put a decent amount on, it'll hold alright. ;) The truck holds something stupid like 7 litres of water in the jacket so it'll be fine. :thumbs:
Posted: Tue Oct 01, 2013 7:49 am
by pedGSR
Ahh ok. Can you recommend a decent brand that you used?
Posted: Tue Oct 01, 2013 9:28 am
by Daniel
Any will do from an autofactor. It's all the same stuff, just ask for high temp RTV silicone. :nod:
Posted: Tue Oct 01, 2013 7:10 pm
Pete
Google Mr2 race series and you should get something like trackattack come up. Steve Vince used to run the Nippon race series and the MR2 one as well. He should be able to help you.
Posted: Wed Oct 02, 2013 7:39 am
by pedGSR
Cheers stu will have a look.
Pete.
Posted: Wed Oct 02, 2013 1:00 pm
by gary@apt
dont just go with out gasket ,sometimes they need thickness of gasket to make covers all align up
