Smoke on Over Run
Posted: Mon Sep 10, 2012 8:09 pm
by hoodedreeper
Got the turbo all fitted to the car,took it on a drive so my friend could tune the MegaSquirt on the go. It drives and boosts fine. Once your in boost and either let off the throttle or change gear,it puffs out some blue smoke.
If i'm approaching a set of lights,and i'm slowing down in gear (doesnt matter which gear) it'll pour out.
Its oil,but cant see why its doing it? I've checked the oil level numerous times and its full (had oil & filter change about 2 months when the car was 'off the road' for the conversion).
The Garrett is brand new,its never been ran. Cant be oil seals as i'm sure it'd smoke ALL the time.
Gaskets are brand new when i fitted the turbo (manifold to head,manifold to turbo,turbo to downpipe). Surely it wouldnt blow a gasket straight away when we first drove it.
Piston rings or valve stem seals seems to be the other options
Opinions?
Posted: Mon Sep 10, 2012 8:23 pm
Did you fit an oil restrictor?
Posted: Mon Sep 10, 2012 8:58 pm
by hoodedreeper
No i havent
Posted: Tue Sep 11, 2012 12:33 am
by Fast Eddy
Did you prime the new turbo and the oil feed pipe and is the drain to sump clear. If so could be stem seals/guides or blow by the rings or just breathing heavy.
Posted: Tue Sep 11, 2012 10:14 am
Posted: Tue Sep 11, 2012 11:14 am
by hoodedreeper
Yes the turbo was primed before we started it to make sure the flow was good. Havent checked oil return yet,will do that this week
Thanks for the link Stuart :)
