Heat wrap cooler pipes
Has anyone used exhaust heat wrap on intercooler pipes ?
Likes ? - http://www.facebook.com/lovablemonkeys
As long as you are selective about which areas you wrap as you could potentially be stopping heat dissipate from some parts.
Yeh seen some do it .
Just got a new double thickness cooler (racespec) and want to wrap all the pipes before cadwell
The reflecta gold and cool tape type products I have used before worked well but seem a little pricey now adays
I have wrapped my Induction pipework in the immediate vicinity of the turbo however the best solution is to insulate the turbo don't know how difficult that is on your car as Eddy states be selective you want to dissipate heat as much as insulate against it
Good under bonnet ventilation is also important
Intake cooler pipes all need wrapping from TB to cooler exhaust side no wrap
Turbo wrap no good like a jacket or something would be nice but no possible
So I'll give it a go then
Black exhaust wrap wanted
I would not recommend wrapping IC pipework (are you talking about alloy pipes or flexible hoses), especially not in Black as that absorbs heat, and yes it will make that much of a difference. You should be wrapping the ancillaries that generate the heat.
Do you measure your intake temps? Do you know what they are at the throttle body?
The DEI CryO2 kit is good stuff if you want to reduce your temps. I run an IC spray bar and my logging shows up to 50 degree drop in temps at the throttle body. They also do an alloy bulb that goes inside the intake pipe and a fuel rail chiller, all good stuff.
You should be able to buy a beanie for your turbo. Bit like a tea cosy for turbos. Goes wrapped around the turbine housing. If you've wrapped your headers, uppipe, and and downpipe either side of the turbo that should cut down considerably on underbonnet temps.
The other options are ceramic coatings.
I used one particular type of coating from a company called CamCoat. Their coating doesn't have to be applied by plasma so you can DIY by spraying it on. I applied satin black coating on my headers, uppipe and downpipe.
After a good session when everything has been glowing red hot, within less than half a minute or so you can touch exhaust pipework and it's just warm to the touch. Even immediately after switch-off nothing is red hot to the touch.
The only thing with this is that unless you want to pay big bucks you should DIY, and then you'll need to prep everything really well prior to application. The finish though is really good and IMHO better than wrap. Once it's done it should last for years.
I agree with warboys, don't wrap your cooler pipework, just make sure it's all getting plenty of cool air, even if you have to route some cold air ducting somehow into the engine bay. Every little bit helps.
Some pics of the coating after prep (80 Grit Aluminium Oxide shotblast) and application. Bare in mind these were brand spanking new shiny stainless steel items.
- Prepped -
- Downpipe -
- Headers 1 -
- Headers 2 -
Hope this helps
- Prepped -
- Downpipe -
- Headers 1 -
- Headers 2 -
Hope this helps
