Apexi VAFC II
cannit
Apexi VAFC II
Post by cannit »
Wow this thing is confusing and the instructions not really very helpful!!
Its all on and fitted and as far as im aware it has made no difference. All i want it to do really is monitor knock and for the graphs to work on the monitor screen but I'm having trouble accessing the screen where you can view things live, like rev / knock / VTEC on / off etc. All i seem to be able to get up is a graph plot that doesnt even tell me what it is measuring!
Anyone any good with these and could possibly go through it with me?
Cheers
Paul
EG6 SIR2
drifter
Post by drifter »
When it's on the graph, push the centre button which should show a menu with Nx. Push the centre button again and it will change the display mode. Keep doing that to cycle through the 4 display types :)
That's presuming you've figured out how to get the monitoring sorted, sounds like you have if you can see a graph.
I had to download the manual to check, but it's the as an SAFC2 iirc. Can't see that it monitors knock though?
cannit
Post by cannit »
Nice one matey, managed to work out how to change the graphs last night, was a bit of a fluke!!! But it is as youve written above, cheers.. As youve said, it doesnt appear that it has the function to monitor knock, I'm sure a friend had one and it did but obviously must have been a different unit... Not sure if the AVCR does?
Anyways its monitoring and looks pretty on the dash and i dont think i'll play with it as could cause more harm than good!
EG6 SIR2
drifter
Post by drifter »
SAFC2 monitors knock, pretty sure the AVCR does as well :) Shame they removed the feature :(
