Headlight Problem
Mr Windscreen
Headlight Problem
Post by Mr Windscreen »
The MX 5 is due an MOT and we have found a problem with the headlights. They come on and work fine but when you try main beam they turn off! The bulbs are new and all the wiring look fine so i havn,t got a clue as to why they are messing around. Any idea,s?
i had this problem on a car once (subaru i think) and it turned out to be a rear bulb gone
wierd i know but it was the problem affecting the headlights
Nik
Post by Nik »
I had a similar problem on the 32. It turned out to be the switch burned out and was sorting out.
ScoobieWRX
Post by ScoobieWRX »
Is there a seperate fuse for main beam. or are main and dipped on the same fuse?
Mr Windscreen
Fuse,s all fine, bloody things worked twice last night and now nothing!!!!!
AdrianP
Post by AdrianP »
Sounds like Nik could be right with the dodgy switch then.
Or maybe a sticky relay?
Ady.
Mr Windscreen
The switch was knackered so a quick look on ebay and everythings sorted.
Nik
Post by Nik »
Glad my info helped. :)
Mr Windscreen
MOT Tomorrow, fingers crossed.
