Brembo Spare Parts
Silver
Brembo Spare Parts
Post by Silver »
Hi everyone.
Was googling about rebuild brembo caliper, and founded Frayz caliper painting guide, very useful.
Iam trying to rebuild the brembo calipers need bit of pointing the right direction.
1. Trying to get new seals, piston and hoses
2. How to take the piston out? (The caliper didnt come with hose otherwise I would pump them out)
3. How to find out what the Max and Min size disc the caliper use.
Calipers are off E38 7 series goin on to the E46 they bolt straight on. I tried.
Pics of the caliper.
Tonynos
Post by Tonynos »
Get in touch with Godspeed Motorsport http://www.godspeedbrakes.co.uk/home.htm they should be able to give you all the info you need.
Tony.
V8_EATR
Post by V8_EATR »
Welcome to BigPower Ernest :)
Silver
Post by Silver »
Thanks guys, I give them a bell tommorrow.
Silver
Post by Silver »
Just another thing how I can get the pistons out???
IWANT1
Post by IWANT1 »
Put them back on the car and pump till they pop, or maybe some compressed air but you would have to make a fitting up.
You dont want to be attacking them with anything that will damage the piston
rayman gtir
Post by rayman gtir »
put some insulation tape round a air line blower and press hard against fitting on caliper, give the trigger a couple of squirts and they SHOULD pop out.
stockcar
Post by stockcar »
we are a Brembo agent and carry a lot of more common parts in stock, can probably sort these for you
alyn
0191-4103770
Silver
Post by Silver »
Ok thanks guys. goin to try force them out with compress air somehow!!
Dont have the hose to pump them out.
Goin to need to order new piston and seals because the guy I brought off already tried to take them out with a screwdriver and damage out edge of the pistons.
So when I get the pistons out I be giving you a call Alyn.
Thanks again for the advice guys!!
