Water leak
Posted: Sun Mar 15, 2009 1:05 pm
by DR GREENTHUMB
Afternoon all. Does anybody know how much of a job it is to get to the heater matrix on a 32GTR as i think mine has sprung a leak. Is it a dash out job or can you get to it easily. Just dont want to start a job and then find out its going to be major interior surgery . Also is it a bad idea to loop the hoses that run through the bulk head for the heater so that i can still use the car as its my daily drive. Any help would be great.
Cheers. Matt.
Posted: Sun Mar 15, 2009 1:15 pm
Dash out job Matt and from experience of doing this a few times, it's a fairly time consuming job (3 hours?) Not sure about looping hoses but I can't see it being a lot worse than water dripping behind the dash where you have electrics everywhere. That question may be worth referring to a grown up ;)
Posted: Sun Mar 15, 2009 1:25 pm
by DR GREENTHUMB
Cheers for the fast reply stu. A mate told me to try the stuff that you put in the coolant :o :o but i dont like useing stuff like that as it only hides the problem untill it gets worse . Oh well , will have to get stuck in then.
Cheers. Matt.
Posted: Sun Mar 15, 2009 3:18 pm
by Gerry H
I've used Wynn's rad sealer to good effect a few times. It may buy you some time,
Posted: Sun Mar 15, 2009 5:26 pm
by ScoobieWRX
Stick an egg in it :D
Posted: Sun Mar 15, 2009 5:37 pm
by Gerry H
ScoobieWRX wrote:Stick an egg in it :D
:roll: Stick a sock in it! :grin:
Posted: Sun Mar 15, 2009 5:53 pm
by IWANT1
Usually no problem bypassing the matrix, stay away from rad weld type stuff as its spread everywhere and can easily block/seal important water ways.
Posted: Sun Mar 15, 2009 6:17 pm
by RX7
I had to change this on my car, what a bugger of a job !!!!
I might be naive and say isnt it only used when you have the heater on hot ? If you turn the heater off it shouldnt use the matrix ?
Posted: Sun Mar 15, 2009 7:21 pm
by IWANT1
RX7 wrote:I had to change this on my car, what a bugger of a job !!!!
Nope, water flows through it continously when you adjust the control a flap would open directing air passed the matrix.
Posted: Sun Mar 15, 2009 8:01 pm
by russ979
Hi matt!
personal experience on this, is that yes a rad sealer may work for a while, but in the long run it will probably shorten the life of water pumps and thermostats (even if they state otherwise!) by far the quickest/safest fix is to by pass the matrix at the bulkhead as you stated :wink:
Cheers
Russ
