Dif Oil
Dif Oil
I am assuming that you can put gearbox oil in the diffs but would like a bit of advice on this before we fit it :?
Yes, just check the grade obviously. If you have an lsd you need a lsd oil of course.
you can as long as its not a plated LSD type.............
would need to be a decent spec anyhows, generally GL5 from memory
