Tyre repair?? urgent
blackskygtr
Post by blackskygtr »
Ok boys and grills
Suz has continued the run of luck with a puncture in the sidewall of a brand new T1r caused by a thorn.
We have been advise it could be repaired but finding someone to do it is the issue.
A small patch on the inside should do the trick as its nowhere big enough to warrant a plug repair.
And plug repair cant be done on sidewall.
Any ideas guys?
Jay
pm micared on here Jason - he should be able to help.
IWANT1
Post by IWANT1 »
Would be very surprised if ANY repair can be carried out on a sidewall.
IWANT1
Post by IWANT1 »
http://www.blackcircles.com/general/repair Doesnt look like it, a can of tyre weld might see you by tho.
Must have been a mighty strong thorn mate !!!!
what size tyre is it jay
jason
Suz
Post by Suz »
sidewaysfletch wrote:what size tyre is it jay
jason
225/45 16
And yes it was a strong thorn for it's size :evil: :evil:
May have sorted the problem, but only time will tell if it's a permanent fix, it's almost a pin prick so no real "damage". It was just letting a tiny amount of air, patch repair is possible but the cost may be a much as a new tyre unless I can find someone in the business :wink:
sorry suz i cannot help, the new tyre i have is 15"
jason
