Six speed 'box into a classic shape Scooby???
Posted: Sat Nov 22, 2008 7:49 pm
by BentMetal
This is a question for those well up on their Scoobies.
Has anyone put a 6 speed box from a later Impreza into a classic?
If so, what else do you need and how difficult is it?
Where can I source a box from? What is the going rate? Or what do these cost new?
I want to put one in my STI V6 wagon because the synchros are on there way out.
Any help/advice will be much appreciated.
Cheers
Posted: Sat Nov 22, 2008 11:11 pm
I am pretty sure that mikeB has done this in his rather gorgeous 25B. May be worth sending him a PM and asking very nicely
Posted: Sat Nov 22, 2008 11:29 pm
by Gerry H
There are quite a few of these conversions been done to good effect.
IIRC you also need the the shorter prop shaft from an auto. The complete set-up usually sells for <2K and are ~30kg heavier. They do handle a lot more torque than the 5 speed, ask Duncan
New synchros would be a cheaper option, or a replacement 5 speed, even less.
Cue Steven
Posted: Sun Nov 23, 2008 7:58 am
by mike-payne
I have the conversion.... just need the box, diff... and rear shafts.
Otherwise you need to ensure your current diff ratio matches the box.
Also need to have the shifter. Also needed a 6 speed to manual speedo cable converter.
Posted: Sun Nov 23, 2008 11:45 am
by BentMetal
Thanks guys.
Just need to track down a 2nd hand 'box, diff and shafts then! Everytime I see these, they sell in no time.
Posted: Sun Nov 23, 2008 12:03 pm
by duncan
22b.com is a good place to keep your eyes on for these - they crop up every few weeks.
Good conversion to do :thumb:
6 speed box
Posted: Tue Nov 25, 2008 9:50 pm
by mikeb
hello matt i did the six speed box conversion in my impreza the thing you do also need is the gear stick as it is totaly different to original also prop as is shorter. I picked up six speed box, stick,prop,rear sharfts, rear big diff,hubs, brembo rear calipers,these all came from a 2002 ra so had no dcd. paid
Posted: Thu Nov 27, 2008 1:32 pm
by BentMetal
Thanks for that Mike.
I've bought a 6 speed from a 2003 STI. I'm not going to change the rear driveshafts, hubs, brakes etc... I'm matching it to a UK Turbo diff and I've got the stick and prop. Maybe not as good conversion as yours, but my immediate problem was to get around my knackered 5 speed - didn't want to spend money rebuilding it only for it to break again.
Maybe in the future I'll go to the bigger rear diff.
Posted: Thu Nov 27, 2008 2:50 pm
by mikeb
Still sounds good mate good luck make sure you got more people to help you put it in than when you take the five speed out.
Posted: Thu Nov 27, 2008 4:03 pm
by stockcar
be better off with an "auto" prop if its for a classic............
