Is this normal
Posted: Sat Nov 22, 2008 5:13 pm
by pablo
Posted: Sat Nov 22, 2008 6:07 pm
Only if your car is fooked
I have saucepans that look like that (but quite a bit larger)
Posted: Sat Nov 22, 2008 6:12 pm
by gary@apt
looks like its been burning a bit of oil but them swirls are normal,is the way the air and fuel mix enters the cylinder
Posted: Sat Nov 22, 2008 6:13 pm
I had hoped that someone with a constructive comment would chip in
Posted: Sat Nov 22, 2008 7:09 pm
by pablo
Cheers gents
I had hoped the oracle of knowledge (Gary) would be around
Cheers Gary.
We plan to clean them up and fit new piston rings is there anything that we should look for or are we better off fitting new pistons.
Posted: Sat Nov 22, 2008 7:14 pm
by Daniel
i was going to say, the cylinders in the mini were like that and they were okay
Posted: Sat Nov 22, 2008 7:15 pm
by gary@apt
fitting oversize pistons will always be best ,but may be get a engine company to measure bores to make sure they dont gone oval
if they ok then a hone of bores and replacement rings
Posted: Sat Nov 22, 2008 7:32 pm
by pablo
Once we get them out i'll check the bores for roundness. That's something i can do
If all is ok we'll go from there, we have 3 options to look at but at the moment it may come down to cost. Due to work situation.
Posted: Sat Nov 22, 2008 7:43 pm
by gary@apt
call me if you need any help guys
Posted: Sat Nov 22, 2008 7:54 pm
by pablo
Thanks Gary..that's extremely generous of you
