AVCR set up etc
evildave
AVCR set up etc
Post by evildave »
scoob is running freeflow panel filter,equal length headers, 3" downpipe, 2.5" system. now fitting uprated fuel pump and AVCR.
what should i be running boost wise to keep it safe for the internals? i think i still have the VF23 turbo.
cheers,
dave
Dave - i'd get it up to Gary at APT to check fueling / det with the AVCR set up - you may be safe to increase boost but better to be safe than sorry.
evildave
Post by evildave »
cheers, i'll give gary a call at some point and see about setting it all up.
