impreza gearbox linkage?
this week my gearbox seems to be getting really loose on selection, mostly going into 3rd. Is there a Nylon bush or something that could be worn? box feels ok and only done about 55k miles.
There's a nylon bush at the bottom of the gear stick but if it were that, then all gears would feel odd imo.
Perhaps checking the linkage bolt tightness at the various yolk (?) connections may help.
they do all feel a little odd, in neutral there is a lot of left to right stick movement with very little resistance, most noticeable going down into 3rd as it's the 'centre' position and requires some guiding, i'll get it up on the ramps at henstead tomorrow and check it out, cheers for the advice
Possibly lost the spring off the back of the box, which helps pull the lever back to the 3rd gate.
If you push the gearstick left or right and it stays there, it usually means the spring has gone.
Simple fix with the right spring and a pair of needle nose pliers.
Toy: 550+ Subaru Impreza Wagon
Commute: E46 M3 SMG
Tow Car/Wifes: Nissan Pathfinder
Commute: E46 M3 SMG
There speaketh the Impreza gearbox expert :notworthy:P20SPD wrote:Possibly lost the spring off the back of the box, which helps pull the lever back to the 3rd gate.
http://www.scoobymods.com/forums/attach ... 838789.jpg
The spring is missing in this pic,but it should be connect the disc on the left and a hole to the bottom right of the top linkage.
However, the phase two boxes dont always have this spring, as the centering is done internally. A sping can still help in this instance though.
Commute: E46 M3 SMG
Commute: E46 M3 SMG
superb and the right diagnosis!
had a look on the ramps and the spring is missing, fitted a temporary one which helps a bit, will order from dealers today:)
cheers guys!
cheers guys!
