Oxy sensor fitted - quick bit of advice please
After about 2.5 hours the old sensor was finally removed and replaced with a new one from Subaru (defo not cheap!!) anyway the cel has now gone out but my silly question is.........will the car need a few miles to "settle" as it has been running in "safe" mood for the last 3 weeks or should it remember all the ecu settings and run normal straight away....probably a silly question but someone has to ask them :lol: Cheers
after being run a few times the ECU will 'learn' that it now has the correct readings and adjust accordingly but personally would get a re-set done to sort properly..............
Got to be done via OBDII port on newage. If you were near me i would do it for you FOC no worries. Perhaps if you ask nicely someone near you might do it as it only takes a couple of seconds once plugged in, and well worth doing.
This is the very same service a Subaru stealership will charge you between
same here, if your north bound we are just at the "angel" off the A1M near Newcastle.........
