caster & camber adjustment
evildave
Post by evildave »
just bought some eccentric alloy top mounts and some in situ adjustable tca's for the mk2.
hopefully will be able to lose the 19mm wheel spacers to reduce bump steer, can anyone give me some advice on set up or where to go to get it done (4 wheel alignment etc)?
cheers,
dave
where abouts are you based?
evildave
Post by evildave »
i'm in lowestoft mate
Fast Eddy
Post by Fast Eddy »
Autotest in Norwich have an excellent rep mate
maff
Post by maff »
2nd vote for autotest in norwich http://www.autotest.org.uk/
Well i'll be able to feed back today as I'm going there @ 13:00
