2ndhand turbos
2ndhand turbos
Hi guys,
If you buy a 2ndhand turbo (something of the T04 variety), what should you be wary of or look out for ?
Can they be rebuilt, if so what are the costs etc ?
Cheers
For starters you want to check for any play in the main shaft and also inspect the blades for any signs of damage.
They can be repaired or rebuilt, when we bought our car the turbo had been sat in someones garage for over 6 years. We sent ours to universal turbo who for about
Jeez for
ScoobieWRX
Post by ScoobieWRX »
Gareth do you mean TD04 or T04. I have a TD04 for sale in very good nic :)
Gareth drives an RX7 so my money would be on a T04 probably Z or E model
Knowing what you are like Gareth, ie exacting, I would go for a new one mate. Otherwise you'll be forever worried about things and the small saving will just not be worth it.
Obviously if you know the car and the owner that the 'secondhand' turbos come from, well, that may be a different matter.
ScoobieWRX
I know bugger all about the RX7 so always open to being educated.
Ta very much :D
alexb
Post by alexb »
G - don't go for a GReddy TD-06 as apparently they are a bit fragile compared to the T04s. Also ball bearing turbos are nice for boost characteristics but beware of premature failure due to the heat from the rotary - simpler tech (T04S) may be better in this case :)
And as Stu says - buy new, you're paranoid enough as it is ;)
Cheers for the responses guys.
Yeah it is a T04 rather than a TD04.
Alex, cheers for the advice re ball bearing turbos.
The whole question came about as there is a 2ndhand T04S setup for
JC
Post by JC »
End float should me minimal, sideways movement is noticeable though, this is taken up by the oil..
I think??
JC
sdminus
Post by sdminus »
Make sure you match the hot side housing for you port. If not you will create a lag monster or worse a turbo with no high end. A 60-1 is a nice spooling turbo and quite cheap. wont give mega power but shoud be good.
