Regarsds Rob
What mods ????
What mods ????
Hi all , ive just got a v3 sti scoob and was wondering what mods i would need to brake the 300 bhp barrier ? its currently got a 3" Kakimoto exhaust , Blitz air filter and will soon have a 3" downpipe , the car already feels really Quick but would like to break into the 300's
Regarsds Rob
Regarsds Rob
S14 silvia stuck at 420 hp and ran out of money !
might already be there, have you got an uprated fuel pump on there because a lazy standard pump was what killed my last engine
best bet get it on the rollers for a power run and check its running all ok, that way you will also find out what the figures are if you need to know
Most subaru tuners wil have te fuel pump in stock - try scoobymania http://www.scobymania.com
Well worth it 8)
Well worth it 8)
What TK said and others, if it's safe it'll probably make 300 on Vpower or Tesco 99 and some octane booster. Use octane booster at every fill to be on the safe side until you get a mappable ecu. Knocklink will let you know if there's a det problem rather than finding out the expensive way.Tk wrote:might already be there, have you got an uprated fuel pump on there because a lazy standard pump was what killed my last engine
