Diesel engine help!
Posted: Wed Mar 12, 2008 4:22 pm
Im looking at buying a cheap diesel runaround so i can take my Impreza off the road for a while, needs a new driveshaft and a few other bits.
The diesel car in question is a Ford Escort 98 LX TD.
He says the "The car runs and drives, however, the engine is quite lumpy and smokes a fair amount."
And "I've been told the smoking and the lumpiness in the engine is something to do with a sensor in the diesel pump, however I have not investigated this and can't be sure for this to be true. I can tell you that there is no knocking from the engine, and she does feel like the power is there when driven so I do not believe it is the big ends at fault."
What do you guys think? Input would be much apreciated.
Thanks in advance.
JM
Thanks in advance.
JM
