Vacuum Advance question
Posted: Wed Mar 12, 2008 12:05 am
Just noticed the vacuum advance on my manta is only running to one carb. It has a split manifold so I am assuming it is therefore only basing the suction on one carb.
Is this correct or do I need to set it so it has a feed from both carbs.
Just wondering if this may be causing the problems I'm having with the car running lumpy either when you put your foot down or when you are cruising with low acceleration.
Suz
Suz
