As some of you may have seen have just bought myself an Opel Manta as a project car.
She is currently running Weber Twin 40 DCOE carbs,as pointed out in main project thread there is no induction/air filter system in place (see pic below will try post better pic when car arrives).
Have done some research on this and appears to be three schools of thought and not sure which is correct so hoping you can help. As you can see appears to be incredibly tight in front of inlets nearest windscreen next to brake servo. The options i have found are
1. Fit trumpet type system with no filter on (concerned carbs/engine will end up full of muck etc)
2. Individual filter for each inlet
3. One system with some kind of induction box over carbs to one filter at front of the car.
All advice on this gratefully received.
Suz
