Looking to do this in prep for this years track events ..any one any pointers on thier own instalation ??..
cheers Gaz
rear break bias kit
Are you planning on just putting in a limiting valve (with a knob/lever to twiddle) or a full bias adjuster on the pedal? The latter gives you full control of front to rear bias but is a major engineering excercise on most cars, the former is just a case of connecting the valve into the lines but only limits the maximum line pressure rather than giving a full adjustment of the ratios.
