Dear all,
I bought a Profec A from japandyno few weeks ago. The manual doesn't give very much information about setting it up.
So, I installed the device, also the controller valve. It wants to learn in "P1" mode (stock base boost level) but the turbo spools always up too much (overboost) which means the controller doesn't have any clue what is going on.
The manual says I will not be able to boost below the stock base boost level. Does this probably mean that the stock boost controller still needs to be a part of the "boost controller"?
I installed the GReddy "stand alone", stock boost controller is just plugged in that the ECU doesnt give a failure.
Thanks for your help.
John
GReddy Profec A boostcontroller set up
Of course I already did that before. Here is the manual : http://www.silviansw.com/manuals/ProfecA.pdf not very user friendly at all.
Hope there is a Profec A user out here.
See you around.
John
See you around.
John
It shoudnt do that should only boost to what the actuator is set for. are u shure u have all the lines hooked up correctly. i no mine worked wonderful on my mk3 supra. not shure if they still have the write up on my old supra site http://www.supramania.com/forums/showthread.php?t=2841 look at there links and see if maybe it will help.
