Toyo Technical Information
Useful for anyone running 888's
http://www.toyo.com.au/Pit%20Lane.htm
I've also got that website saved even though we don't at present run Toyo's. May have to switch from Kuhmos next year :(
alexb
Post by alexb »
Interesting, thanks Dunc :)
Cheers,
Alex
tomcat
Post by tomcat »
interesting but very vague 28-41psi listed for mine !
is the vehicle weight including driver?
mike-payne
Post by mike-payne »
pablo wrote:I've also got that website saved even though we don't at present run Toyo's. May have to switch from Kuhmos next year :(
??? You have to run Toyo's to pass scruitineering in TA...
IWANT1
Post by IWANT1 »
Thu Dec 06, 2007 7:57 am
You on the beer mike......?
DunkRA
Post by DunkRA »
another tire site to bore you all to death with :-D
http://www.carbibles.com/tyre_bible.html
some of its actually quite interesting in a non dork kind of way :)
I miss my scooby :(
Ran 888's with 34 psi hot at the front and 32 at the rear. This is what the Toyo tech guy said for me at Knockhill, I think they needed a tad more pressure in the front as my neg camber is not huge.
mike-payne
ha ha... yeah must have been!!! :grin:
tomcat
Post by tomcat »
dynamix wrote:Ran 888's with 34 psi hot at the front and 32 at the rear. This is what the Toyo tech guy said for me at Knockhill, I think they needed a tad more pressure in the front as my neg camber is not huge.
I had mine at 28psi hot at donny, toyo guy reconed should have been closer to 35psi which surprised me a bit..
I ran 2.5deg of camber at the front and had a fair bit of understeer, I've read up on the original specs (on slicks) and they used to run 4deg!
Not sure if you should run the same on r888's as slicks?
Have you measured your tyre temperatures/across tyres after a session?
I was thinking of trying this next time with temp probe or ir gun to see as the toyo rep reconed I would be able to see if the car had the right amount of camber...
