Page 1 of 3
Radiator problems in my '96 S14...
Posted: Wed Sep 26, 2007 6:01 pm
by V8_EATR
Takes about half a week to go through all of the coolant in my radiator! :x Has been giving signs of overheating about once a day. Top hose looks good and tight, and all the seals sound normal. ALL heat is gone from the heater and when I turn it on only freezing cold air comes out (never warms up). What to do??? I'm tired of filling the coolant every three days
Posted: Wed Sep 26, 2007 6:16 pm
by Tk
need to get that heater working soon if todays weather is a sign of things to come , could be a simple airblock , im sure someone will be along soon to put you on the right track
Posted: Wed Sep 26, 2007 6:33 pm
by Ben
Drive up and see gary - get him to diagnose the problem - and save yourself a load of grief
Posted: Wed Sep 26, 2007 7:01 pm
by stockcar
whatever the cause, sounds like you now have an airlock hence the lack of heater..........
as above you need it sussed asap as even a small issue will become a nightmare in short time
Posted: Wed Sep 26, 2007 7:16 pm
by 323ian
Have you drained the system recently?
Is there any leaks?
Does the car smoke?
Posted: Wed Sep 26, 2007 7:51 pm
by pablo
Don't like to say this and I hope i'm wrong, but it sounds like you may have a head gasket problem
But then again what do I know.... I drive a Ford.
Posted: Wed Sep 26, 2007 8:24 pm
by V8_EATR
323ian wrote:Have you drained the system recently?
Is there any leaks?
Does the car smoke?
Haven't fully drained the system since I bought it in June.
when i turn it off, it does sound like something hot is dripping onto the ground, maybe coolant from the lower rad outlet?
no smoke, thank God!
Any queries Ian???
Posted: Wed Sep 26, 2007 8:51 pm
by V8_EATR
Finished pm tagging Gary, and he also believes it to be a head gasket issue! Going to see him Friday......this sucks
I'll keep everyone posted. Thanks for the direction there Ben, always a help you are.
Posted: Wed Sep 26, 2007 9:23 pm
by Ben
- Bryan, I wasted 2 months on my car when Gary could have figured it out in ten minutes ... he's your best bet for a quick turnaround.
Posted: Wed Sep 26, 2007 11:19 pm
by Bladerider
Not totally narrowed down yet,
Headgasket
Cracked head
Cracked block
Liner shifted :x :x :roll: :roll:
Rad fooked
Water pump fooked
Thermostat fooked
Fan fooked
Any of the above,
J.
