Radiator problems in my '96 S14...
V8_EATR
Post by V8_EATR »
Takes about half a week to go through all of the coolant in my radiator! :x Has been giving signs of overheating about once a day. Top hose looks good and tight, and all the seals sound normal. ALL heat is gone from the heater and when I turn it on only freezing cold air comes out (never warms up). What to do??? I'm tired of filling the coolant every three days
need to get that heater working soon if todays weather is a sign of things to come , could be a simple airblock , im sure someone will be along soon to put you on the right track
Drive up and see gary - get him to diagnose the problem - and save yourself a load of grief :)
stockcar
Post by stockcar »
whatever the cause, sounds like you now have an airlock hence the lack of heater..........
as above you need it sussed asap as even a small issue will become a nightmare in short time
323ian
Post by 323ian »
Have you drained the system recently?
Is there any leaks?
Does the car smoke?
Don't like to say this and I hope i'm wrong, but it sounds like you may have a head gasket problem :(
But then again what do I know.... I drive a Ford.
V8_EATR
Post by V8_EATR »
323ian wrote:Have you drained the system recently?
Is there any leaks?
Does the car smoke?
Haven't fully drained the system since I bought it in June.
when i turn it off, it does sound like something hot is dripping onto the ground, maybe coolant from the lower rad outlet?
no smoke, thank God!
Any queries Ian???
V8_EATR
Post by V8_EATR »
Finished pm tagging Gary, and he also believes it to be a head gasket issue! Going to see him Friday......this sucks :( I'll keep everyone posted. Thanks for the direction there Ben, always a help you are.
:) - Bryan, I wasted 2 months on my car when Gary could have figured it out in ten minutes ... he's your best bet for a quick turnaround.
Bladerider
Post by Bladerider »
Not totally narrowed down yet,
Headgasket
Cracked head
Cracked block
Liner shifted :x :x :roll: :roll:
Rad fooked
Water pump fooked
Thermostat fooked
Fan fooked
Any of the above,
J.
