what is the vanos on a bmw :?: i have an e36 k reg 325i coupe would this have one or not ,
jason
vanos
- Mr Fletcher
vanos
[SIGPIC] [/SIGPIC]
not sure it was on that early, but certainly appeared by around 97-98, as bruv used to have a 528i with it fitted...............
slarty bartfast
slarty bartfast
Single VANOS
VANOS is a combined hydraulic and mechanical camshaft control device managed by the car's DME engine management system. The VANOS system is based on a discrete adjustment mechanism that can modify the position of the intake camshaft versus the crankshaft. Double-VANOS adds continuous adjustability to the intake and outlet camshafts.
VANOS operates on the intake camshaft in accordance with engine speed and accelerator pedal position. At the lower end of the engine-speed scale, the intake valves are opened later, which improves idling quality and smoothness. At moderate engine speeds, the intake valves open much earlier, which boosts torque and permits exhaust gas re-circulation inside the combustion chambers, reducing fuel consumption and exhaust emissions. Finally, at high engine speeds, intake valve opening is once again delayed, so that full power can be developed.
VANOS significantly enhances emission management, increases output and torque, and offers better idling quality and fuel economy. The latest version of VANOS is double-VANOS, used in the new M3.
VANOS was first introduced in 1992 on the BMW M50tu engine used in the 5 Series.
Double VANOS
Later BMW added "double" VANOS to its M52tu engine series of inline 6 engines, which changes the mechanism from fixed position operation to continuously variable, and add the same functionality to the exhaust camshaft, on a number of its cars. Double-VANOS (double-variable camshaft control) significantly improves torque and emissions since valve timing on both the intake and outlet camshafts are adjusted to the power required from the engine as a function of gas pedal position and engine speed. On most BMW engines that use a single VANOS, the timing of the intake cam is only changed at two distinct rpm points, while on the double-VANOS system, the timing of the intake and exhaust cams are continuously variable through a range of ~40 crankshaft degrees for the intake, and 25 degrees for the exhaust. The advantage of double-VANOS is that the system controls the flow of hot exhaust gases into the intake manifold individually for all operating conditions.
Double VANOS
E46 325 CI + 1999 Pajero 3.2 + E36 M3 track car 3.2 and a Mini cooper S Vert!!!
- Mr Fletcher
thankyou for the information slarty i will take a picture tommorrow , it was just that i had heard of vanos
problems and expensive repairs but had no idea what it was.
many thanks
jason
many thanks
jason
[SIGPIC] [/SIGPIC]
