Timing Strut
Posted: Sun Jul 29, 2007 7:57 pm
Does any one know the regs for a timing board, size, height anything that i need to know ???
lee
lee
Bigpower car enthusiasts
https://bigpower.kardiak.co.uk/phpBB3/
https://bigpower.kardiak.co.uk/phpBB3/viewtopic.php?f=66&t=12435
after a bit of searching i found this does it sound correst some of you sprinting boys should know!The Beam Breaker must be mounted vertically, on the front of the car, so that it's leading edge is the furthest forward point. It must be of solid material (ie metal or wood) and matt black. It must be 51mm wide, 254mm high with 200mm ground clearance.
It must be in place when presenting the car for scrutineering.
