R32 GTR aircon removal?
Nik
Post by Nik »
Hi guys,
I am wanting to remove the aircon on the GTR whilst I have the engine bay in a mess to replace the relocation kit etc.
Is it possible to do it myself or do I need someone to do it for me? i.e draining the system etc.
Do I need any parts to block anything off or change anything etc or is it just a case of removing the parts that are to do with the aircon?
Any advice would be greatly appreciated.
Cheers
Nik
martin
Post by martin »
Just pull the pipe of and stand back
Remove the aircon pump and pipes and the aircon rad you will need a different Aux belt if you remove the pump
Nik
Post by Nik »
Ok, thanks Martin. Luckily the aircon pump runs off of a seperate belt so that won't be a problem. :)
martin
Post by martin »
Just make sure you DEFO DO NOT breath in any of the air con gas stand well back
jazzymonkey
Post by jazzymonkey »
You should really have the system professionally de-gassed as the gas is not very environmentally friendly. And the planet is in a bad enough state as it is.
Stands down from soap box. :)
JM
martin
Post by martin »
jazzymonkey wrote:You should really have the system professionally de-gassed as the gas is not very environmentally friendly. And the planet is in a bad enough state as it is.
JM
When cars are in crashes the gas comes out then :?:
And why pay a stupid amount to have it degassed when pulling a pipe of is free :D
jazzymonkey
Think of the Polar bears. :(
Nik
Post by Nik »
martin wrote:Just make sure you DEFO DO NOT breath in any of the air con gas stand well back
You should try getting a face full of that stuff. I was helping a mate to take the engine out of his R33 GTR and he told me it had been degassed. Guess what? It still had pressure in the system so when I undid one of the pipes it spat the gas and tracer all over me. I looked like the incredible hulk :D. He then got his UV lamp out and it was even more impressive.
Luckily, I have cat-like reflexes and managed to shut my eyes and mouth. :D:D
