AFM/boost problem
Ian200sx
AFM/boost problem
Post by Ian200sx »
My R32 GTR has picked up a odd glitch.
I haven
mk1 escort, supercharged.
TonyB
Post by TonyB »
Are you running a boost controller? Is it working? Is 0.7/0.8 base actuator pressure?
'05 Subaru WRX 300
R.I.P
'89 ST185 GT4
ONLY 370bhp & 405ft/lb @ fly
12.7s 1/4 @ 109mph in the wet
R.I.P.
Stock is 0.7 -0.8 Tony, spot on.
Ian200sx
Post by Ian200sx »
I am running a boost controller with the PFC I had thought it was stock boost but it struggles to hit 0.7bar at the moment. Also why would the warning light come on?
But will go check all the connections again :-D
gary@apt
Re: AFM/boost problem
Post by gary@apt »
ian,
didnt we have problems with afms when mapping it??and light coming on at high boost
sounds to me if it had a leak its getting worse.....
Ian200sx
Post by Ian200sx »
Yeah they were maxing out at 1.2 bar.
I don't know where to check, all the IC pipe works been off and seems ok but the DV stuff hasn't and the boost controller pipes haven't been 100% checked as there a bugger to get to. Can i run the car with out DV's?
Guess i'll have to start again checking for any air leaks, failing that you'll get the car back to sort it :-D
TonyB
Post by TonyB »
Ian200sx wrote: Can i run the car with out DV's?
2" of Yard brush handle is not for off the size for plimbing the big pipe, tighter the better, be sure to sand bits off, if you can find nothing more appropriate, and just block the small pipes. <queue hillbilly music>
Quick and easy test to see if it is the DV's, they can seize/leak.
'05 Subaru WRX 300
R.I.P
'89 ST185 GT4
R.I.P.
TonyB
Post by TonyB »
oops
'05 Subaru WRX 300
R.I.P
'89 ST185 GT4
R.I.P.
Ian200sx
Post by Ian200sx »
Well today I thought I
Fast Eddy
Post by Fast Eddy »
Not necessarily mate,
Remember when the car is running and on boost you have a positive pressure acting on the back of the piston/diaphram to help keep it shut. When you let off power this turns into vacuum and helps the valve to open under the remaining boost pressure in the IC pipe. The std valves in good nick are meant to hold up to 1.5 bar according to RK!
I tested mine by removing them altogether and runing the car without. I did this by making up stainless blanking plates to go on the DV flanges.
Stu has some that he may let you borrow.
Hope this helps
