Hi chaps ...needing a little advise here in using 2 fuel pumps ...
I have this set up on the car however they are both intank and "Y" off into one delivery at the fuel rail ..
recomendation and poinions needed here as Its going so well i dont want to leave any thing out ..
I have locked out the Hicas so there is 2 hard pipe lines available to flow fuel ...SO
flow 2 pumps into one feed to the fuel rail
Flow indervidual pipes one each end of the fuel rail and use the center as a regulated return ..
any help or advise would be muchos appreciatos
cheers Gaz
fuel pumps
jazzymonkey
