Nismo charging stabalizer?
V8_EATR
Post by V8_EATR »
Has anyone used one of these? My friend has one on his R33 and he said it worked as it should, just wanting an opinion from anyone who has heard anything. :-D
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... &rd=1&rd=1
Is that for real or some make believe uber gizmo? .... Bryan what makes you think you need it?.
Looks like the emporor's new clothes to me :)
323ian
Post by 323ian »
Keep well away mate!!
I cant beleive firms can get away with using the Nismo brand name wihtout having legal action taken against them?!
There is nothing genuine Nismo which would cost that price.
V8_EATR
Post by V8_EATR »
murano3 wrote:Is that for real or some make believe uber gizmo? .... Bryan what makes you think you need it?.
My lights are very dim and I just replaced them with 8000k bulbs and its starting to idle very unstable, for example, I started her up a couple of days ago to let the wife back out of the garage and when I pulled back in, immediatley after I stopped, the car shut off! :x Ever since then every time I stop the revs are never stable!
V8_EATR
Post by V8_EATR »
323ian wrote:Keep well away mate!!
I knew there was something wrong with this name being this cheap :? , but like I said my friend recommended I try this to help out my idle problem. I'll be sure not to get my hopes up! Thanks Ian
Better idea, before you part with the readies.... why not post up a general technical question on how to fix a power drain type problem.
jungle-jim
Post by jungle-jim »
V8 dude, may i ask how often the S14 comes out?
i would advise you check the quality of your battery before blowing your "hard earned" on this 'stuff' ;)
V8_EATR
Post by V8_EATR »
[quote="jungle-jim"]V8 dude, may i ask how often the S14 comes out?
i would advise you check the quality of your battery before blowing your "hard earned" on this 'stuff' ]
I drive it everyday twice a day, to and from Thetford! I usually keep the boost between 9-10psi daily and up to 12.5psi (max for the GT28R) on the track.
Thanks for the idea Ben, done!
