Another problem!?!
Posted: Sun May 20, 2007 1:46 pm
FFS this month is just a bad month for the Cat i think :!:
Just had a trip to Tesco's up the a11 from mine and was getting steering wobble :!: :?:
The car was wobbling at 70-80mph :!: and then under braking it was wobbling only slightly, however as i went around the roundabout the car made a scrapeing noise, like something was rubbing:?
So i pulled over checked the wheel and inner arch to see if that was the problem however it all seemed fine :!: :?:
Got in the car the wobble wasnt there, and when i turned into another turning the scrapeing noise wasnt there
However i turned right again and the noise was back again :!: :evil:
I'm going to get the car jacked up at some point this week to see if maybe its a wheel bearing :!:
Would i be right in this way of thinking or is there something else that it may be :!: :?:
I have tried making sure the tyre pressures are all ok and they are:!:
I'm getting narked with this car at the moment all i seem to be doing is fixing niggles and glitches
