Wilwood brakes - should this happen?
Posted: Tue May 01, 2007 7:58 pm
by Tommy
Hi. Some of you may know I attended a trackday at Bedford a couple of weeks ago. My friend came along in his car which is equipped with Wilwood calipers, pads and discs. This is the result of the trackday (he only did about 15 laps duing the day)
Should this happen? I've never seen such a severe fracture on a disc.
Posted: Tue May 01, 2007 8:18 pm
by duncan
They look really deeply scored - were they like this beforehand?
Posted: Tue May 01, 2007 8:25 pm
by Tommy
not completely sure but I don't think so. The set up has probably done less than 1000 miles.
Posted: Tue May 01, 2007 8:28 pm
by duncan
what car was this on?
Posted: Tue May 01, 2007 8:34 pm
by Bubble
I have seen worse.......
I cracked one of my new discs right through from one side to the other @ Snetterton, as some people saw :o
Poor quality rotors, insufficient bedding-in and heat cycles, rotor to bell mounting stresses, etc. etc. can all cause problems.
by Tommy
on a Magnum 427SF (a Cobra replica). The calipers are 4 pots and the car is light - very light.
Posted: Tue May 01, 2007 8:36 pm
by Tommy
Bubble wrote:I have seen worse.......
He's replaced the rotors with more items from Wilwood but the highest spec they do, so hopefully it won't happen again. We shall see after The Ring later this month.
Posted: Tue May 01, 2007 8:38 pm
by Ben
How have the replacements been ? .. or not tracked them yet?.
Posted: Tue May 01, 2007 9:00 pm
by Bubble
I am running AP Rotors with the K-Sport set up and once I have bedded them in a bit more, I will try and kill them on a trackday - all paid for by Apex Performance :D
Posted: Tue May 01, 2007 9:37 pm
by Lloyd@JRD
As Geoff said, there are many contributing factors to this.If everything has been done correctly, 100% then no it shouldn't. However, it could be a number of things from the rotors being installed at with the wrong torque rating, to a sticky piston to not being run in correctly.
It could also be a severely warped hub, however, he should have felt this through the steering wheel.
Personally, I'm not a Wilwood fan. I will recomend AP, Endless or Brembo for a caliper upgrade, but it is entirely up to the cusomer.
Geoff,could you please let me know how you get on with the K-tech set up, either pm or give me a call, it would be much appreciated.
Hope he gets on ok with the new rotors
Lloyd :-D
