Maestro turbo injector size?
Ian200sx
Post by Ian200sx »
I can't find what size injectors a Maestro turbo uses. I need to work out what power they are good for to rule out if i'd maxed them out with my escort. Thanks if you can help.
Also if anyone happens to know what 40's throttle bodies are good for power wise would be good (2.1 engine) :D
    mk1 escort, supercharged.
    martin
    Post by martin »
    Pm Gareth on her mate he knows them like the back of his hand :-D
    Re: Maestro turbo injector size?
    Post by Gareth »
    Ian200sx wrote:I can't find what size injectors a Maestro turbo uses. I need to work out what power they are good for to rule out if i'd maxed them out with my escort. Thanks if you can help.
      Maestro Turbo's dont use fuel injector's, just a single SU carb. EFi MG Maestro's (non-turbo) did use fuel injection however, although these too are very hard to find, people used to use XR3i Injectors as an upgrade on these.. and they are far more common to find.
