scooby pcd
scooby pcd
can someone tell me what the PCD and off set is of scooby 4 stud alloys because seen a nice set on ebay and the guy said that the PCD is 108 the same as a ford, is this right :?
http://www.carlsalter.com/wheel_fitments.html
http://www.raceandroad.com/studpatterns.asp
I would say that he may be right, but I'd ring a Subaru dealer to double check as the two guides above quote the 5 stud only.
(PS~ If you want baby 15" wheels, I have three or four sets)
110 pcd for up to 2005 and 114 pcd onwards.
thanks for the info guys did think that it was not right.
pre 05 is 100 pcd 5 hole.
offset is 53 on the classic and 48 for new age iirc.
>05 the pcd is 114.3 don't know the offset
HTH
