rear anti roll bar bushes sticking?
Posted: Wed Mar 28, 2007 6:21 pm
by duncan
It feels like these are sticking when I am driving very slowly - ie 5-10mph and clunking/knocking as a result.
There is no noticeable noise when driving or handling defects.
Is this likely?
If it is, is it easy to remedy by taking the ARB off and re-fitting/greasing?
If not the ARB bushes, what else could it be? ... top mounts?
Posted: Wed Mar 28, 2007 6:48 pm
by stockcar
could be top mounts or shox as both are known issue's (on a std car)......................
be worth re-greasing the roll bar as you mention as its possible or could it have worked loose??
Posted: Wed Mar 28, 2007 6:54 pm
by 323ian
Are you sure the anti roll bar drop link has not broke as mine did on the Mazda and gave the same symtoms?
Posted: Wed Mar 28, 2007 7:40 pm
by duncan
stockcar wrote:could be top mounts or shox as both are known issue's (on a std car)......................
it sounds and feels like it is coming from the bottom not the top mounts.
Will jack it up tomorrow and see if I can check the drop links - maybe give them a spray with wd40 to see if that frees them
Posted: Wed Mar 28, 2007 7:57 pm
by 323ian
The drop links on a lot of cars are thin studs with bushes either end and prone to rust.
They are not seized.
Posted: Wed Mar 28, 2007 9:39 pm
by duncan
Ian - checked the drop links and they look fine. I will give them a thorough check shortly.
Alyn, when greasing what is the best way to do this?
ie. wheels on ground (or ramp pref) and undo ARB bolts so that lower end bushes in accessible.... I presume put grease around the bush and the bar that goes through the bush??
Posted: Thu Mar 29, 2007 8:19 am
by Lloyd@JRD
Is it whilst turning or light bumps in the road i.e?
Posted: Thu Mar 29, 2007 8:26 am
by duncan
very light bumps in the road at low speed.
Have just checked with my friendly subaru dealer and will be getting the struts changed under warranty :D
Posted: Thu Mar 29, 2007 8:42 am
by Lloyd@JRD
thats what I was then going to say, the Mitsubishi ones are terrible, I have known of customers going through pairs in 6 weeks in some instances, now on coilovers :-D
Posted: Thu Mar 29, 2007 12:17 pm
by duncan
going in tomorrow for them to be checked and hopefully get changed next week if in stock :thumb:
