Latent Heat Transfer
Posted: Tue Mar 27, 2007 6:19 pm
a post on another forum (yes i do frequent others
) led me to start thinking whether different liquids are better at cooling. The case in question:
Intercooler Water Spray on the Impreza works by spraying the warm/hot intercooler with water which then evapourates. It is the latent heat transfer at this evapouration stage and not the cooling done by the water itself, that causes a reduction in the temperature of the intercooler.
Question is:
What is the best liquid for this heat transfer?
Someone must know, its bleeding years since I did A level physics
Question is:
