Intercooler Water Spray on the Impreza works by spraying the warm/hot intercooler with water which then evapourates. It is the latent heat transfer at this evapouration stage and not the cooling done by the water itself, that causes a reduction in the temperature of the intercooler.
Question is:
What is the best liquid for this heat transfer?
Someone must know, its bleeding years since I did A level physics
