Harness question.
Nik
Harness question.
Post by Nik »
If I got a 6 point harness, would I be able to leave the bottom 2 straps off and just use the top , or would I have to use all 6?
Any theories?
Nik
BenTaylor
Post by BenTaylor »
You can just use 4 :)
At least you picked the right place for the question? :)
Nik my old fruit,
Why buy a six point when a four point will do? Is this one of your super duper deals, ala Nick the Greek from Lock Stock :) Pray tell oh Mohican'ed one :notworthy:
Sarah
Re: At least you picked the right place for the question? :)
Post by Sarah »
stuartstaples wrote:Nik my old fruit,
mohican is no more, it left the building about 10 days ago and is replaced with a number 1 all over :)
Aint this where I should put something witty ?
Nik
Post by Nik »
It is true. The heek is no more. :D.
I only ask as I have aquired one 4 point harness and was looking on ebay for one to match but the only one that matches at the moment is a 6 point one.
stockcar
Post by stockcar »
if its either a cheaper 6pt or a 4pt converted to 6 then you can easily use just the 4 points as the buckle will be attatched to a side lap strap
however, would not advise using a pukka 6pt without the crutch strap as they have the buckle attatched to this and therfore you can't remove the lower straps.................
i have a couple of pairs of decent 4/5/6 point belts removed from competition cars re; date issues although having had relatively low use.............
**cars competing in MSA/FIA events have to have dated harness's**
Nik
Post by Nik »
Thanks for that, any pics of the 4 pt and a rough price please? :)
