Problem with the clutch/gearbox
Econ
Post by Econ »
About 2 months ago I had an Exaddy paddle clutch put in my R34. Now recently I have started to experience a few problems.
1. When ever I put it in reverse it crunches every time
2. Sometimes it
Did you change the fluid at the same time? Did you get a new release bearing at the same time? When was the last time you changed your gearbox oil? Gary @ APtuning is an Exedy dealer so it may be worth asking him. (About the symptoms, not about the other things I asked :) )
Econ
Post by Econ »
Yes new bearing and gearbox oil was done at the same time as the clutch.
benh
Post by benh »
Where is the clutch bite when you get the crunching behaviour? Close to the floor?
If so i think the clutch isnt quite lifting and is dragging a little. You ought to be able to adjust that out.
The other possibility is that the incorrect gear oil grade was used and when its cold its just that little bit off spec.
Cheers,
Ben.
Econ
Post by Econ »
This is actually when i first put it in gear so the the peddle is flat to the floor. The gearbox oil is Millers so it should be good enough and I used the same oil in my R33 and had no problems but I might change it to redline shock proof stuff anyway.
The symptoms you are listing are the same as when my twin plate failed. I warped a plate - it showed itself as a really low bite point, was a bugger to get into first and reverse. To get first sometimes it was best to select 4th, then 1st.
Econ
Post by Econ »
Well if it is the clutch I am going to get an OS Gilken tripple plate this time
If you're spending the money - get the nismo copper mix or the HKS GD Max instead.
I've still got my OSGiken sitting in a box - maybe one day i'll actually have it rebuilt but who knows.
Econ
Post by Econ »
Dont rate the OS Gilken clutches then?
I liked mine - but it was a bit agricutural - very much on or off. Wasn't town friendly.
